Fortissimo II - Will it output 6.1?
Discussion in 'Desktop & Laptop Computers Forum' started by Messiah, Jan 15, 2003.
  1. Messiah
    Messiah
    Apr 22, 2002
    7,529
    +339
    Does anyone know if this card will output a 6.1 audio signal via it's optical S/PDIF output?
    The box says it supports 5.1 but I would guess if the output stream is 6.1 then it will pass that to my 6.1 amp which will do the processing. Not looking for any on card processing.
    Anyone any ideas?
    Thanks.
  2. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    If it does DD and DTS 5.1 it will also be able to do 6/7.1. My understanding though is that the Fortissimo II is one of the poorest cards on the market. Id stay clear, I'd buy a SB Live 4.1 ahead of that one.
  3. Comer
    Comer
    Sep 21, 2001
    1,365
    Ireland
    +82
    I agree. I had this card and it was a disaster. It contributed to stutter and the sound would stop it I so much as looked at the keyboard. It also caused freezing of the picture with TT software that I never have experienced with my MAudio
    Conor
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Comer, you're putting the PC in the freezer now? Will your quest for the coolest PC in Ireland never cease?
  5. Comer
    Comer
    Sep 21, 2001
    1,365
    Ireland
    +82
    :D :D :D
