forgot how to put a theme on to my wd live (SMP)
Discussion in 'Video Streaming Boxes & Services' started by Goldeneyepad, Mar 10, 2013.
  1. Goldeneyepad
    Goldeneyepad
    Aug 13, 2012
    103
    Was wondering if anyone can help, i have forgot in how to put a theme onto my wd live. I have aSMP machine. I used to do it thought my computer and
    I know the password is admin but that all i know. Where do i go to put it on
    Thanks for reading
  2. Goldeneyepad
    Goldeneyepad
    Aug 13, 2012
    103
    Can anyone help
  3. STUKAVICH
    STUKAVICH
    Aug 18, 2006
    96
    +11
    From memory type wdtvlivestream into the web browser of your pc connected to the same network.This should bring up a page where you type admin as the password.then go appearances or similar and point it to the zipped theme file on your pc.I believe the zip file has to be under a certain size and I recall that using Internet explorer wouldn't work for me , I had to use chrome.Hope that's correct and helps.
  4. Goldeneyepad
    Goldeneyepad
    Aug 13, 2012
    103
  5. Goldeneyepad
    Goldeneyepad
    Aug 13, 2012
    103
    That not it?
  6. tea_bag
    tea_bag
    Dec 4, 2007
    286
    28
    +76
    If I remember right, it's use google chrome (not IE) and type in your smp ip network address, login with "admin". click apearence tab. browse and submit your theme zip file.
  7. Goldeneyepad
    Goldeneyepad
    Aug 13, 2012
    103
    Thank you tea bag
