Dinsdale
Hi guys
Glad to say I’m now up and running with the following setup.
- Denon AVRX4500H receiver.
- 5 x Monitor Audio W280-IDC in-wall speakers
- 4 x Monitor Audio C625-IDC in-ceiling speakers
- 1 x Monitor Audio IWS-10 in-wall subwoofer
- 1 x Monitor Audio IWA-250 in-wall amplifier
There’s just one small snag - the neighbours.
Originally, I was informed that I would simply need “egg foam” to wrap around the speaker recess in my cavity wall to deaden the sound for the neighbours. This was important to me as the last thing I wanted to do was annoy the neighbours with belting sound - I know I’d hate this... but I naively thought the egg foam was the solution.
Unfortunately, this has proved not to be the case when I’ve did some tests with the neighbours. The egg foam might as well not even be there.
So, what next? Well, I’ve been doing some research (admittedly the same research I should have done before the project started). It seems Monitor Audio do backboxes for my W280-IDC’s... but they’re a whopping £150 a pop. Spending another £750 isn’t going to be an easy pill for me to swallow - so I wanted opinions.
It means I’m going to have to cut bigger holes in the wall and replaster over the damage before placing my cables back. Doable, but a bit of a ball ache.
Here is the link to them: WCBOX-L | In-Wall Back Box | Monitor Audio
My questions are:
1. Is this the right approach? If not, what is?
2. Will these really contain the sound for the neighbours benefit?
3. Are there better alternatives?
4. Are there cheaper alternatives?
My questions are:
