Foreign Channels available on Sky Digital?
Discussion in 'Sky Digital TV Forum' started by PoochJD, Jul 29, 2002.
  1. PoochJD
    PoochJD
    Aug 28, 2000
    11,001
    Norwich
    +1,861
    Hi Folks,
    Just got the latest piece of advertising gumph through my letterbox, more commonly known as the Sky TV "SKY GUIDE" monthly magazine.
    Normally, I only skip through it, as it really is a complete waste of paper and ink, but one letter on the BACKCHAT letters page caught me eye.
    According to Sky, It is possible to get "France2" and "Nile TV" via an ordinary Sky Digital set-top-box, as long as you know the frequencies. Typically, the frequencies aren't mentioned, and I can't locate any other information about these 2 stations, on my normal "non-listed Sky TV channels" website page.
    So, do any of you kind folks know if you can get any other Foreign TV channels, bar CZ3 and Abu Dhabi TV, including the two mentioned above?
    If so, please would someone be kind enough to post the names and frequency details in this thread?
    Thanks ever so much,
    Pooch
  2. TobyAnscombe
    TobyAnscombe
    Jul 24, 2000
    238
    28
    Essex
    +26
    Just to add to this - Just forked out for a Sky+ install and would like to get some French TV as both my girlfriend and I speak French. Is this possible off a Sky setup?
  3. LDR
    LDR
    Apr 1, 2002
    2,332
    Wales
    +101
    Get any good quality Satellite mag from your local WHSMith or whatever, turn to the sat listings & it will give you the frequencies of the channels, just type them into your skybox & away ta go !
  4. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,279
    Manchester
    +762
    Read the $ky FAQ at skydigitalfaq.cjb.net/
    Your digibox is limited to only 2 symbol rates (SR) i.e. 22000
    and 27,500
    So you have to choose channels whose multiplex uses 1 of these symbol rates.
    You can see good listings, colour-coded as to which ones are FTA (Free To Air) at www.lyngsat.com (yellow=digital FTA).
    Chris Muriel, Manchester (author of Digital Satellite FAQ)
  5. TobyAnscombe
    TobyAnscombe
    Jul 24, 2000
    238
    28
    Essex
    +26
    Ok, excuse my ignorance but my sky disk must be pointing at a sat to get a signal does this mean that due to the angle etc i cannot get the other chanels without moving the dish?
  6. Xeonic
    Xeonic
    No, it means you need another sat box :(
    The digibox is a bit like an LW radio, ok for a few stations, but all the other channels are on FM! You first need a separate box to receive RTL, RAI e.t.c. and all the other channels which are on frequencies which the digibox can't pick up (like chris said!). Then optimally a second dish, to pick up these other stations while the digibox stays pointed at 28.5E (where the sky-based stations are). Have a look at the FAQ and start from there ...
