Ford (Mondeo) CD Player - Juke Box compatible
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by mattrixdesign, Nov 3, 2004.
  1. mattrixdesign
    mattrixdesign
    I have just purchased an '02 Ford Mondeo TDCI 2.0 Zetec.
    It has the standard Ford CD head unit and state it is CD Changer Compatible. Would any CD changer work? or does it have to be Ford?
    Can you advise a cheap after market changer, where can it be installed in the car? etc
  2. Mr Cheese
    Mr Cheese
    Dec 12, 2002
    412
    Down South
    +19
    I looked into this some time back. Avoid Ford as they were charging well over the top - £200+ IIRC. You can buy a Sony changer for about £80 and an adapter for your car for about £50. There are companies that sell car manufacturer compatible packages for about the same price eg Ford Six CD changer.
    Hope this helps.
  3. mattrixdesign
    mattrixdesign
    Where would you have the actual CD changer located? I guess boot is the only option?
    Thanks for the info!!!
  4. Mr Cheese
    Mr Cheese
    Dec 12, 2002
    412
    Down South
    +19
    ...Or under the front passenger seat (if there's room!)
  5. toratosaru
    toratosaru
    I also have a Mondeo with the same CD player, can anyone tell me if I i has a 'line in' auxilliary input. I want to connect my MP3 player form it's 'line-out' to play through the car audio.
  6. jtf
    jtf
    Nov 19, 2004
    220
    colchester
    +7
    a company called mes make adaptors for the ford stereo's that will give you a line input. i think they are about £70 though.
