Ford ka 2004 error codes: p0136 and p0134
Discussion in 'Motoring' started by p1tse, Aug 24, 2013.
  1. p1tse
    p1tse
    Jul 24, 2008
    2,974
    68
    +83
    I've googled the results but what does this mean in terms of fix £
    [​IMG]
  2. un1eash
    un1eash
    Nov 14, 2007
    4,996
    2
    +1,416
    Looks like the pre cat o2 sensor has failed, cost £25-80 for a new sensor. It could be the wiring at fault also, on some cars if the wire is in contact with the exhaust it can melt through.
  3. p1tse
    p1tse
    Jul 24, 2008
    2,974
    68
    +83
    It's come back on for the second time, as it did go away before
  4. un1eash
    un1eash
    Nov 14, 2007
    4,996
    2
    +1,416
    I'd check the wiring first then. Find the sensor and follow the wiring back to either a 3 or 4 pin plug. It could be this plug that is the problem.
  5. p1tse
    p1tse
    Jul 24, 2008
    2,974
    68
    +83
    Been quoted circa £150 for sensor and labour
