Ford Focus Stereo Replacement
Discussion in 'Motoring' started by whoareyou, Jan 30, 2009.
Thread Status:
Not open for further replies.
  1. whoareyou
    whoareyou
    Jul 9, 2004
    126
    16
    Im looking to replace my factory fitted stereo in my x-reg/2000 ford focus.
    I have bought a facia and iso leads, but am worrided if i take the old one out and decided to put it back in, will i need the security code?
    Anyone have any experience?
  2. Ron240
    Ron240
    Jan 3, 2002
    3,630
    Kirkcaldy (but i'm not a Fifer)
    +472
    You will presumably be upgrading(little point otherwise), so cant see any reason why you should want to go back to your old model....but yes, if it uses a security code, then it naturally wont work without it.
    There are ways around security codes...but would you really want to go to all that unnecessary trouble?
  3. kentish_lad
    kentish_lad
    Sep 14, 2006
    1,627
    Kent
    +192
    Post up the serial no (starts with a 'M' + 6 digits) i can then give you the CODE incase you wish to refit in the future
  4. Hamm
    Hamm
    Feb 12, 2009
    Hi i also need the code for my x reg ford focus stereo
    serial no is M176484
    hope you can help me cheers
  5. Ayub
    Ayub
    Oct 15, 2003
    6,647
    Bradford
    +612
    If you supply him the code you will be breaking forum rules and a MOD WILL have words. Codes are not permitted now If this post was posted in the correct section you would of seen the sticky AVForums.com - Announcements in Forum : In Car Entertainment (ICE)
    I'm sure you understand, if not please message a mod http://www.avforums.com/forums/private.php?do=newpm&u=11045
    Who will explain this.
  6. Ayub
    Ayub
    Oct 15, 2003
    6,647
    Bradford
    +612
    NO CODE sorry.
  7. IronGiant
    IronGiant
    Jun 7, 2003
    66,485
    +46,688
    As above...
    Dave
Thread Status:
