Ford Focus Key Fob
Discussion in 'Motoring' started by iloveapple, Jul 29, 2012.
  1. iloveapple
    iloveapple
    Mar 27, 2012
    28
    Hi All,
    I have recently purchased an 02 Ford Focus Zetec. The Key Fob seems to be problematic, it will lock the car and open the boot, but the 'unlock' button does not work. Do I need a new key fob? If so, will I need to go through Ford? Or can I purchase a fob on eBay, and find someone to programme it?
    Thanks.
  2. paulyoung666
    paulyoung666
    May 4, 2006
    13,513
    Teesside
    +3,842
    Pretty certain a locksmith will be able to sort you out , ford will be mega expensive ....
  3. Ayub
    Ayub
    Oct 15, 2003
    6,658
    Bradford
    +612
    The fob is ok only the micro switch ( for the isticukar command) is faulty.
    Any repair shop will fix it for around £10 or do.
    Stop pushing the button hard! It's not a remote :p
  4. ajex
    ajex
    Dec 1, 2007
    1,293
    48
    +56
    Try changing the button cell battery!!! You can get it off bay for as little as 99p and poundland as well...
  5. SyStemDeMoN
    SyStemDeMoN
    Feb 27, 2008
    4,108
    2
    137
    Tipton, West mids
    +857
    Try and get it fixed but if worst comes to worst then get another one off of flea bay and its easy to program it by yourself. Its in the manual or just google it, but its something like turn the ignition on and off 4 times in 6 seconds and then press lock on the fob.
  6. zircon3035
    zircon3035
    Feb 23, 2005
    517
    46
    Uncertain
    +158
    I've fixed a few of the type used with late 1990s Fords. With these, remove the back cover and then prise the PCB assembly out of the top cover. The push button matt should remain in the top cover. Check that the "fingers" on the PCB (where the conductive pad on the back of the buttons touch) are clean. You will probably find they are dirty or greasy. Carefully wipe these clean with an alcohol wipe, then reassemble the unit. In most cases, this should fix the problem.
    And as Ajex says, change the battery while you are at it.
    HTH,
    Ian
  7. iloveapple
    iloveapple
    Mar 27, 2012
    28
    Can't seem to find a repair shop that can help me fix this issue! :confused:
  8. iloveapple
    iloveapple
    Mar 27, 2012
    28
    Don't think it's a battery issue because all of the functions work apart from the unlock function. Wish it was a 99p fix though! :(
  9. ajex
    ajex
    Dec 1, 2007
    1,293
    48
    +56
    Many years ago ,I had similar problem which was solved by changing the battery i don't think u will find 1 sure shot remedy...
