Ford focus 58 plate
Discussion in 'Motoring' started by moggyheckles, Aug 27, 2013.
  1. moggyheckles
    moggyheckles
    Jun 24, 2012
    71
    11
    Just got a 1.6 zetec, it sounds v throaty but i believe it has the normal size exhaust and back box. Is it meant to sound throaty?
    Also the steering wheel shakes over 55 mph, thoughts on what could be?
    And lastly first time I've had a Ford not sure if just me but it doesn't seem to like crawling along the mway in first gear?
  2. Naaktgeboren
    Naaktgeboren
    Jul 13, 2007
    8,817
    Kashyyyk
    +7,286
    First question, did you not test drive the car before purchase? :eek:
    The wheel shaking could simply down to misalignment/balancing, prob worth getting that checked out.
    As for the noise you mention.. that is not normal for a 1.6 zetec engine, how many miles does it have on the clock? Does it have a full service history? How long ago was the MOT? Any items on the advisory?
  3. moggyheckles
    moggyheckles
    Jun 24, 2012
    71
    11
    I did test drive it but don't recall the noise but always a lot to take in when test driving a car:(
    Has FSH asked dealer to put on 12 months mot (it was 6 Mths) no advisories on mot.
  4. moggyheckles
    moggyheckles
    Jun 24, 2012
    71
    11
    23.5k miles
  5. redaprilia
    redaprilia
    Feb 10, 2010
    931
    43
    +120
    Get the front wheels balanced , but its very likely the wheels themselves are bent or have flat spots -- our roads are in such a state that wheels can get wrecked easily .
    Small petrol engines will sound growly ( it probably the air intake you are hearing rather than the exhaust ) and tend to hunt on very light throttle due to attempts to keep the emissions under control . You could replace the plugs and air filter just to be on the safe side but I doubt its faulty in any way .
