ford fiesta 53 reg help connecting mp3 player
Kawsar17
Hi guys, basically I want the simplest way to connect an mp3 player or anything with a 3.5mm jack to my car.
The problem is I have this head unit:
http://www.fitaudio.com/storedimages/ford_fiesta_new/headunit1.jpg
So replacing the car stereo is tedious and expensive, halfords don't even do it.
If the car had a cassette player I would just buy a cassette adaptor but it doesn't.
Any help or advice would be great guys as I can't go on burning all my mp3s onto cds.
koush
Your options are;
1) you can get a fm modulator that transmits the sound to you radio and you just tune in your radio to pickup the audio.
2) you can remove the oem stereo and fit an aftermarket stereo. you would have to either cut the 2 bars and fit a double din sized stereo, you can buy from ford a facia that has the bar removed so you can fit your oem back in when you sell.
Koush
