Forced to reformat DVD-RAM??! (Panasonic DMR-E50)
Discussion in 'Blu-ray & DVD Players & Recorders' started by tony_mes, May 5, 2005.
  1. tony_mes
    tony_mes
    This may be very very simple to someone??
    I have a Panasonic DMR-E50 dvd-ram recorder.
    If I program it to record on DVD-R, all works fine
    If I program it to record on a ram disc (which i have formatted), it doesnt work, and when I return the display says "UNFORMAT" and disc info says unformatted disc
    If I press the "record now" and record whatever I am watching, all works fine.
    I have eliminated to possibility of having a faulty disc, I am definitely formatting the disc first, what on earth is wrong - is it the player thats is faulty?
    Any words of advice much apprecatiated...
    Tony
  2. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    Have you tried a different disc? sometimes discs just have to junked its a fact of life.
    Gary
  3. tony_mes
    tony_mes
    Yea, I even got a new ram disc in a protective caddy to make sure.
    It just works differently if I program instead of press "record now". I would conclude there is something wrong with the machine, except that everything is fine if I do record instantaneously - I can edit, make playlists, everything..
    I am hoping it is some simple error on my part... :rolleyes:
  4. Logo Hater
    Logo Hater
    Nov 26, 2002
    515
    Lancs
    +24
    Why do you format new RAM discs. I have used more than 50 new RAM discs and I haven't ever formatted any of them.
    If I re-use one that has been recorded on previously, I just delete the existing programmes and re-record.
    The only disc that I have ever formatted has been the Hard Disc, I find it advantageous to do that occasionally, I have a DMR100.
    I don't understand why you feel the need to format a new RAM disc, it isn't necessary. :thumbsup:
  5. tony_mes
    tony_mes
    Why? Out of desperation!
  6. Logo Hater
    Logo Hater
    Nov 26, 2002
    515
    Lancs
    +24
    Well I would suggest you try using them without formatting them. It is worth a try just to see if it makes a difference.
