Forced Software Download
Discussion in 'Satellite TV, Sky TV & FreeSat' started by scottly, Jul 25, 2004.
  1. scottly
    scottly
    How do you do the title? :lease:
    :oops: Sorry I meen an EPG Forced software Download for Sky + digibox?
  2. Fernsehman
    Fernsehman
    Easy. After you click on "New Thread" you'll see a message box and a box above that labelled "Title". Type your message title in there. Just like you typed "Forced Software Download".
  3. sinbrad
    sinbrad
    Disconnect your box from the mains. Hold in the backup button and plug the box back in. Keep hold of the backup button until the front panel lights up. If you have your box connected via scart you will see a message on screen telling you that the update is in process and not to do certain things whilst this is happening. Once completed the box will switch itself off. Wait approx 20-30 seconds and then switch on as normal, update will have been completed.
