force 42in plasma
Discussion in 'Plasma TVs Forum' started by tradesman, Aug 13, 2004.
  1. tradesman
    tradesman
    Aug 13, 2004
    107
    16
    Has anyone experience of this model ie performance and connectivity seen one for sale for under £3000 bit of a technophobe myself so any advice wellcomed
    regards tradesman
  2. Dr Downey
    Dr Downey
    Jan 12, 2004
    124
    19
    Cheltenham
    That seems a bit steep in price, you can get a nice Panasonic 42" for just under £2k from one of the forum sponsors.
    Good luck
  3. tradesman
    tradesman
    Aug 13, 2004
    107
    16
    Fair enough m8 just thought someone might have a clue about the one I had in mind didnt think it was compulsory to buy from the sponsors
    regards tradesman
  4. Koing
    Koing
    Nov 21, 2003
    189
    16
    It isn't 'compulstory' to buy from the forum sponsors but the Panasonic 42" for just under £2k is a STONKING PRICE bar NONE.
    Quality is amazing.
    Koing
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    would you buy a car from Laguar-Benz???? Then why buy a Plasma made by a company called Force????
    For £3k you could buy Panny, Fujitsu perhaps even Pioneer. what are you looking for?Whats budget???
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,784
    The Borders
    +3,289
    Tradesman
    The limited amount of info on the Force web site certainly doesn't point at this being a top flight display - no mention of YUV Component or HDMI/DVI with HDCP inputs on the Media Box.
    Contrast ratios are always difficult to use as a guide but 1000:1 on a low end unit usually points at non real world readings.
    Also the Plasma 42 doesn't appear on the UK distributors web site - so possibly not available in the UK.
    £3k for this unit looks expensive - look in the Power Buy section of the AV Forums we have the final few (very few) Pioneer PDP-434HDE PlasmaTV's with speakers, table top stand or wall mount and UK delivery all for £3.5K ; and as others have said your also looking at nearer £2k for a Panasonic 42" Display which does have an excellent pedigree.
    I'd keep on searching!
    Best regards
    Joe
  7. tradesman
    tradesman
    Aug 13, 2004
    107
    16
    Thanks all will take a look at what the sponsors have to offer its just that I saw the Force on sale in my local satellite store at around £2500 and was wondering if anyone had knowledge the more I look the more ideas I get even been looking at LCD tv
    regards tradesman
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Where abouts are you tradesman? £2500 gets you a very nicely equipped plasma list what you need, dont need.
    Ie Table mount?
    Tuner?
    Speakers?
    etc etc
  9. tradesman
    tradesman
    Aug 13, 2004
    107
    16
    Hi hornydragon m8 I live just outside Manchester I have got to build a cabinet to hold all my stuff goin to build it so it will house a 42in plasma will be connecting all my gear to it incl multi sat receiver, freeveiw box, dvd player/recorder, subwoofer possibly vhs video recorder so will need table mount and speakers.
    regards tradesman
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    PW6 with table stand and speakers <£2500, excellent deal. for similar money you could buy a hitachi but panny wins hands down. try suoerfi in Manchester, also other AV dealers and get a demo, £3k is alot for Brand X unit especially as LG/Samsungs can be had for under £1700. £3.5k would get you into HiDEF Plasma territtory
    http://www.av-sales.co.uk/plasma/html/panasonic_th-42phd6.html
