For those concerned about resolution.....
The Dentist
I just read this article. Don't know if it's a credited author or not but seems to have some knowledge and ties in with everyone like me concerned with screen size and resolution.
http://www.carltonbale.com/2006/11/1080p-does-matter/
I don't like the thought of his prediction of 2009 and double the resolution. See my other thread on 1080p oversold?
If he's right, the new 1080p tv's will be superceded in as little as 20 months ??
Also explains at what distance and screen size the resolution becomes a notable factor.
Any thoughts???
Jonstone
!080p will not be superceded in 20 months.
If you look at his graphs he is basically saying that if you have a 50" screen which is bigger than most people will have, you need to sit a maximum of 8 feet away from it to benefit from 1080p which is closer than most people sit
So he is saying that you need 1080p but his figures suggest that the majority of people don't
The Dentist
what about later on in the article....
1440 and 2160 mentioned 2009
pjskel
The Japanese have been playing with 1440 and 2160 technology for the past 2 years at least, but it's a long way off from being ratified for use, in much the same way 1080p is the preserve of movies and not broadcasters.
So, it's likely to be 5+ years off before it becomes worth even discussing.
The Dentist
thanx pjskel,
It's good to have people on here with a breadth of knowledge.
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
