For the MOT Experts
Discussion in 'Motoring' started by Joe90sDad, Aug 28, 2006.
  1. Joe90sDad
    Joe90sDad
    Jan 28, 2006
    585
    28
    Location Location
    +44
    Seems there are a few of you guys on here who know their MOT stuff.
    I wanted to know if it's possible to pass an MOT with a space saver wheel and tyre on one corner?
    Cheers! :)
  2. NWhiteley
    NWhiteley
    May 29, 2005
    2,043
    Westhoughton
    +96
    no, it is a fail. the 2 tyres on an axle have to be the size. ie, wheel size, eg 14", aspect ratio, eg 70, and width, eg 185.
    except where the tyre aspect ratio is 80, eg 175/80T14, it can also be, 175/82T14 or 175T14
  3. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    24,105
    2
    In a secret location with Jennifer Lawrence
    +11,256
    I'm not a MOT expert, but the space saver wheel is only supposed to be used to get you home, good for about 50 miles I think, so definitely not for day to day use, so would imagine it would definitely be a failure.
    Just done a quick search and found on the honestjohn forums a discussion about this and people have confirmed if you have a space saver wheel in use it will fail the MOT.
  4. mattlad
    mattlad
    Apr 3, 2006
    157
    +11
    Fail
  5. NWhiteley
    NWhiteley
    May 29, 2005
    2,043
    Westhoughton
    +96
    i wonder though....... what if a car came in with a pair of identical space savers on the same axle, would it fail????
  6. Miniholic
    Miniholic
    Apr 26, 2001
    3,059
    The Shire
    +399
    Technically it might not fail, but it would look :censored: stupid though.:devil:
  7. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    On a similar note, would a car fail if the front tyres were of a wider lower profile than the rears?
    My old Rover 214si had 185-60-14 on the front and I think 175-65-14 on the rear. Not the standard size but the handling was far better:)
    I know it's standard practice on sports cars to have wider rears, but this was no sports car:D
  8. Miniholic
    Miniholic
    Apr 26, 2001
    3,059
    The Shire
    +399
    My old 214 passed with 195/50r15's on the front and 185/55r15's on the back. I needed the extra rubber on the front to tame that 103bhp.:rolleyes: :D
  9. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Mine had a full Janspeed system :p
    :rotfl:
  10. riget
    riget
    Feb 21, 2005
    1,571
    48
    leicester
    +48
    If I remember space saver wheels are a fail, even if 2 are fitted on the same axle.
  11. Miniholic
    Miniholic
    Apr 26, 2001
    3,059
    The Shire
    +399
    The twin exit one? I was going to put one on mine, but it was written off before the exhaust went.:oops:
  12. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Yep, two lovely square oval pipes that filled the bumper perfectly, sounded gorgeous :cool:
    Mine lasted ages, until finally the cam carrier started leaking fluid of some sort into the plug bores :(
  13. NWhiteley
    NWhiteley
    May 29, 2005
    2,043
    Westhoughton
    +96
    cheers, i thought i would be. I dont think that a RBT could be carried out either
  14. riget
    riget
    Feb 21, 2005
    1,571
    48
    leicester
    +48
    Yes that's a way out of having to pass an item that should fail but you can't, so just refuse to RBT.
    Another is saying you want to road test it but it's not road legal. (Is road testing still an option? It was 3 years ago).
  15. Joe90sDad
    Joe90sDad
    Jan 28, 2006
    585
    28
    Location Location
    +44
    Okay, cheers to all. :)
  16. Layne RIP
    Layne RIP
    Sep 22, 2005
    708
    Abbotsford
    +11
    No... provided they are the same across the axle you'd be fine!!
  17. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Thanks, always worth knowing what's safe and legal:thumbsup:
  18. Panosg
    Panosg
    Sep 19, 2004
    898
    Somerset
    +3
