? for the Guru's
Discussion in 'Home Cinema Speakers' started by BAN5HEE, Aug 5, 2004.
  1. BAN5HEE
    BAN5HEE
    Jul 26, 2004
    4,225
    Chelmsford
    +519
    I have a 85 watt panasonic amp. The speakers connected are marked at 6ohm and so are the connections at the back of the amp. If I connect 8 ohm speakers will I blow up:
    a) The Amp?
    b) Myself?
    c) Half the know universe?
    d) All of the above.
    Thanks!
  2. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    Nope. None of those. Plug in and be happy.
    I should point out that half the known universe would include You and the amp, therefore d) is not necessary :lesson: :rolleyes:
  3. BAN5HEE
    BAN5HEE
    Jul 26, 2004
    4,225
    Chelmsford
    +519
    Damnit Karkus you are correct! :eek:
    I retract d from the possible options of destruction then :D
  4. booktrunk
    booktrunk
    Feb 6, 2004
    623
    Leicestershire
    +3
    HANG ON!!!
    I know it's unlikey but it could be the half of the universe you are not in. So it should still be in the list :)
    Steff
