For Lightscribe users
Discussion in 'Computer Software & Operating Systems' started by lisa burrell, May 2, 2007.
  1. lisa burrell
    lisa burrell
    Any other lightscribe users out there? The actual Lightscribe Cd's seem thinner more flimsy than the normal Cd's. But i think when there printed look very profesional. I like them.
    what i wanted to tell you is i found a supplier that's really cheap. My local shop said they are not stocking the media because it will not take of, and think its wasting shelf space especialy the Cd's .
    I found these guys below offering a very good price for them
    and there now in different colours.
    If your a user too, check this out
    http://www.bigpockets.co.uk/product.php?lang=&product=HPBP30&gclid=CKCLmKbQ74sCFRoOZwodlnV3Qw
    [email protected]~~
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,112
    Galactica C.I.C.
    +346
    Thanks lisa.
    Got a light scribe dvd burner a few months back for my lap top indoors. only used it for my own complilation music CDs but was very impressed with the results:smashin:
  3. Bassline@ddict
    [email protected]
    Dec 20, 2002
    459
    Iver
    +14
    Cheers for that, just had a lightscribe dvd writer delivered today. I'll definately be trying it out soon. Those coloured disks look very cool. What software do you guys use? I think i remember reading that theres something on Nero 7 Premium which i have so i'll prob give that a go.
  4. lisa burrell
    lisa burrell
    There is also this
    http://www.lightscribe.com/ideas/labelgallery.aspx?id=219
    These are pretty cool this is a link to the Lightscribe free gallery create yourself a folder give it a name keep it in my pictures and down load all of these templates to it, for your CD writer to burn on to disc. Tell us what you think please when you burnt one on. I think they look quite snazzy.
    Im using vista and lightscribe software hear http://www.lightscribe.com/downloadSection/windows/index.aspx
    http://www.lightscribe.com/ideas/labelgallery.aspx?id=833
    http://www.lightscribe.com/downloadSection/windows/index.aspx?id=810
    and Nero 7
    [email protected]~~
  5. Lakeuk
    Lakeuk
    Jul 20, 2003
    247
    Kendal
    +20
    The biggest downfall for lightscribe is the cost of the discs, you link works out at 35p (plus p+p) per cdr, my last lot of inkjet printable dvdr's worked out at 18p (inc p+p) per dvdr.
    To improve lightscribes chances they need to get it's cost down to sub 20p per dvdr, sad consider you can get a lightscribe capable writer for £20
  6. lisa burrell
    lisa burrell
    Thanks for that do appreciate the input Lake . But you got to agree... looks pretty cool when there done I am quite happy with them.
    My only bug bearer is I need make Cd's for me and not give them away. :)
    Reason i gone to lightscribe i was a big user of fellows.
    then my software would not work properly on vista so i took the lightscribe plunge. Don't regret it at all. Got to spend your money on something.
    [email protected]~~
