For All Those With Tosh Sd Models Who Have Mailed Me For Cd Hack Here Ya Go
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by bigjonnyauk, Nov 3, 2004.
  1. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    761
    midlands
    +17
    HI ALL i have had a lot of emails for this disc and to be honest im not sure i would have the time to send them all out so here is the file and instructions have had reports it works on most sd models mine is the 220
    make sure you follow the instructions escpecially the burning ones
    SORRY I HAVE JUST REALISED THAT THE FILE IS ON A SITE WHICH CONTAINS SOFTWARE WITH SERIALS WHICH I THINK IS AGAINST FORUM RULES
    I DO HAVE THE SOFTWARE SO IF YOU WANT IT LET ME KNOW CATCH ME ON MSN [email protected]
    its a .zip file so use a program called winzip or winrar to unzip it.
    get a program called Nero burning ROM.
    Start Nero Burning ROM, click File, click Burn Image..., select the .cue file, click open, disable 'Determine maximum speed' and 'Simulation', at write method select Disc-at-once (this is very important), click write.
    make sure u have a blank disk in the drive to write to.
    once this is done,
    - Push setup on the SD220e remote control, select under picture:
    PAL/Auto: Auto. Push setup again.
    - Open your SD220e disc tray and insert the CD.
    - Close the disc tray.
    - The disc will be read and recognised as a VCD, you'll see the image on
    your television flash and after a short while you will not see any image
    at all. Wait about 10 seconds and take out the CD.
    - Your player is now region free.
    AND SOME REPLYS ASWELL
    I followed these instructions on the SD330E and have had no problems (R1 / R2 tested) + mp3's still work okay too
    When you insert the disk you will see a pic in the background very dim saying something like 'the wiz' or summit, (didn't see it until too late doe!) and then you will see FIN on the screen. I counted 10 seconds after FIN dissapeared then took the disk out, inserted a region 1 disk and it worked, yippeeeee, haha.
  2. Hawklan
    Hawklan
    Oct 20, 2001
    6,758
    Essex
    +317
    Do you know if this will work with a SD9000E
    Many thanks
    RON
  3. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    761
    midlands
    +17
    hawklan i dont know if you want to try i can send you the file but you try at your own risk
  4. Damian1978
    Damian1978
    Jul 15, 2000
    4,513
    107
    Fleetwood, Lancashire
    +260
    Hmmmm I to would like to know if it would work on the SD900e. I've heard some people say that it worked on a lot more people players than the SD220e. I think one of them might be the SD2109.
    I don't think it changes the firmware....just unlocks something.
    Any chance of the file? I'll hold onto it for a bit and see. :blush:
