For About £50 .....
Discussion in 'Headphones, Earphones & Portable Music' started by John, Dec 11, 2004.
  1. John
    John
    Dec 13, 2002
    10,931
    +2,619
    what should i get . Simple really.
    Have seen hundreds on ebay for less than that ,but are they really any good.Have seen the ones in Dixons that have been "reduced" to about that (can't believe I'm looking at stuff in Dixons :suicide: )
    Go on suggest something :D
    Tia
    John
  2. alancolledge
    alancolledge
    Feb 2, 2004
    518
    Middle England
    +5
    John, I assume you are after a portable MP3 player. If you are quick Aldi have the Medion player back in from last Thursday.
    128Mb internal memory, expandable with sd/mmc card, upto 512Mb. Has a built in voice recorder, mini speaker, usb plug works for hours off a single AAA battery, the size of a elongated matchbox and all this for £39.99. :smashin:
    I've got one, superceeded it with an Ipod. If a 1 gB card worked I might not have had the Ipod.
    Although they might be sold out now.
  3. John
    John
    Dec 13, 2002
    10,931
    +2,619
    Cheers alan , can't believe I didn't put what I was looking for :blush:
    I'll try to get down to Aldi tomorrow , working today
    ta
    John
