FOOBAR! THERE ARE RAINBOWS ON MY SONY KV28-LS36U TV! -PLEASE HELP! (Pictures inside)
sainthalo
Woke up this morning and suddenly my TV has gone to this:
What the hell is this and how do i fix it? Does it need degaussing?
It is 14 months old and I have spoken to Hyperfi where I bought it and they have said to turn it off for a few hours and then back on and there should be a big click and it should then be okay. Sadly this has not worked yet - still like the above mess!
I dont have any unshielded speakers near it - its been the same setup since i bought it. However last night i charged up my nikon camera battery using a socket near the left of the tv and on the right side left my paper fax machine (unplugged and not used)!
Any help gratefully received!
ismael-1986
Established Member
Hi there, it looks af is the shadow mask has been knocked out of place hence the craaaazzyy rainbow effect im sorry to say :thumbsdow , but then again its not like uve thrown the tv on the floor and tryed to plug it bk in so it cud be interferance from that NIKON device u was charging who knows, best of luck anyway :smashin:
per-Sony-fied
Established Member
Never a good idea to watch your TV outside in the rain. Sunshine and showers always cause this affect. :D :rotfl:
sainthalo
DRGL said:
Only it being a Sony means no shadow mask doesn't it?
You da man!
http://repairfaq.ece.drexel.edu/sam/crtfaq.htm#crtemf
So What Does It Mean to Have a Trinitron CRT?
Trinitron is a CRT technology developed by Sony. The patent has recently expired and therefore other manufacturers are free to offer similar CRTs. The CRT uses a set of fine vertical wires called an aperture grill instead of a steel shadow mask to separate the R, G, and B electron beams and force them to strike only the appropriate colored phosphors. This in conjunction with an in-line set of electron guns is supposed to provide a brighter image with simpler convergence and purity adjustments....
i been told that
a) my fax DC motor has magnets...
b) a hairdrier works like a degaussing wand...
any views mate?
per-Sony-fied
Established Member
sainthalo said:
no mate its a problem with the tv not a rainbow on telly.
Woosh.... straight over......
Guess humour wrong time wrong place.
sainthalo
Sorted - hairdried it then left it in standby for an hour or so and back on with a click. Now its working well again - phew must keep that fax machine away from the tv!
sainthalo
Sorry was in a less than humourous mood.
Have now scheduled to laugh at your joke subject to it being humourous - dont hold your breath! :D
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
