fones w/ unlimited vid clip record
Discussion in 'Mobile Phones Forum' started by s_1, Mar 10, 2006.
  1. s_1
    s_1
    which new camera fones are not limited to 30 secs of vid recording you guys can reccommend?
  2. Daddy k
    Daddy k
    Jul 19, 2004
    9,083
    coventry
    +1,351
    most new nokias!
    u must go into settings and adjust it to "maximum" then its just dependant on your mem card.
    also most windows based pda's
    i can record over 2 hours on mine.
    not sure on other makes sure some owners will let u know
  3. clonmult
    clonmult
    Se W550, K750, W800 ....
  4. drlau9
    drlau9
    Jul 22, 2004
    216
    Kettering, Northamptonshire
    +4
    Hey,
    If you fancy to h4ck your phone, or mod it.. Motorola's the way to go. My Motorola V3x had a limit but it's been taken off and now records for 6.xx hrs to transflash card.
    But if you don't want to h4ck, get a siemens S range, Nokia N , Sony Ericsson K series + W series, Sharp 903/ 902.
    Dr
  5. s_1
    s_1
    any sites where i can lear more bout h4cking or where can i get it done in london?
  6. drlau9
    drlau9
    Jul 22, 2004
    216
    +4
    It's a home made job, You can do all the mods from he comfort of your armchair.
    http://www.motomodders.net/Default.aspx?tabid=55
    http://www.motox.info
    Warning, You are responsible for your own phone, the website and I will not be held responsible if you damage your mobile.
    Right disclaimer outta the way...
    Simple process really, all the posts are explained very clearly, even I get it :clap:
    You start from modding skins, then unlock camera recording time, change ext. wallpaper when flip open, you can boost the speaker volume + mic gain + internal speaker volume to your hearts content (seem editing), debrand your phone, enable full motorola features (some network handsets locks features) etc.
    All hardware is included when you buy the phone, you just have to download the softwares.
    Here's a link for all your h4cking needs;
    http://www.motox.info/showthread.php?t=1297
    Dr.
  7. Artmuzz
    Artmuzz
    Jan 25, 2006
    20
    Why would you want longer record times? as video capture resolution is crap on mobile phones unless there is a h4ck to make the resolution better than the maximum setting.
    I know that the video resolution is crap on my V3x even on maximum resolution.
    Artmuzz
  8. drlau9
    drlau9
    Jul 22, 2004
    216
    +4
    Artmuzz,
    That is one of the hacks, another hack I find useful is the ext. vol increase, Internal Speaker gain, + Mic gain All boosted to about 8 outta 10. There's virtually No distortion so the h4ck was worth while, well If you want better resolution you might have to wait for a few months before motorola updates their camera software.
    Tbh It depends what you do, I only unlocked my cam record time cause I'm in college and there's some crazy things happening in 6th form, I can't justify bringing my slr cam w/ vid recording up to 30fps 640x480 in.
    I pumped up the volume cause I'm usually around in noisy environments.
    If you don't wanna mod, don't mod. Simple As :rolleyes: :smashin:
    Dr.
