Following on from the coke thread below...
Discussion in 'Mobile Phones Forum' started by baggy1, Sep 2, 2005.
  1. baggy1
    baggy1
    I've managed to get some water into my SonyEricsson S700i rendering it useless I'm told.
    As there's such a small amount of damage caused to the circuit board, is there any way of repairing this? The chap in the store that I bought the phone from did say that cleaning the affected area with alcohol of some kind could do the trick - any ideas?
    Also can i not just replace the circuit board or is everything on the phone now knackered?
    Any advice would be good. :lease:
  2. JayCee
    JayCee
    Jan 20, 2004
    20,087
    Lanarkshire
    +1,914
    Give the affected area of the circuit board a scrub using an old toothbrush and clean water. Dry it off using a hairdryer at a low heat setting.
    If that now works :smashin:
    A new circuit board (if you could source one) would cost more than a new phone.
