follow turn feature NW HD5
C
crackerbunny
:hiya:
forstly, thanks to the dude with the volume patch
what is 'follow turn' thing?
as i understand it if i turn the player 90 degress the display will move accordingly...however i can't get it to move.
the bizare thing is, i don't care if the display is static, i just wondered if i had the right end of the stick so to speak
any help gratefully received
crackerbunny
It only works when you turn the machine on. Furthermore, if you hold the player nearly horizontal (like many people do) the feature doesn't work.
The BIG PROBLEM With Your Home AV System EXPLAINED
Back
