FolkArt ALR DIY Screen
Discussion in 'Projectors, Screens & Video Processors' started by riddleace, Jan 28, 2018.
Tags:
  1. riddleace
    riddleace
    Nov 19, 2015
    246
    czech
    +62
    Hello, I would like to share with you about my DIY screen experience using metallic colors
    How to paint it...
    FolkArt ALR Painting
    How its look in wery bright room
    Over night with lighst and etc...
    if you have any questions, I'd like to answer on it
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    14,088
    UK.
    +3,491
    Certainly looks effective. Can you take a pic with a (large if possible) white sheet of paper on the screen so we can see the difference between white and ALR?
    Cheers.
  3. riddleace
    riddleace
    Nov 19, 2015
    246
    czech
    +62
    Hi, just made some with white paper on the top... :)
  4. Peter Parker
    Peter Parker
    Apr 6, 2001
    14,088
    UK.
    +3,491
  5. riddleace
    riddleace
    Nov 19, 2015
    246
    czech
    +62
    Thanks... i am so happy with this paint mix... :)
  6. Vila
    Vila
    Aug 5, 2002
    1,573
    2
    116
    +797
    Nice workmanship
  7. riddleace
    riddleace
    Nov 19, 2015
    246
    czech
    +62
  8. kopmjj
    kopmjj
    Nov 4, 2009
    1,853
    48
    +82
    hi mate will this work with 900 lumens projector xgimi h1 seems brighter than 900 lumens to be honest? i was recommended folk art gunmetal over at avsforum by fttoast , but i think the image was a bit darker than expected, but it seems you added more sterlin silver into the mix, does this make the image brighter than just using 12oz of gunmetal grey? also is this the right poly to use?
    i have 2 options
    https://www.amazon.co.uk/Rust-Oleum-Varathane-200261H-Water-Based-Polyurethane/dp/B000LNW7ZM
    https://www.amazon.co.uk/gp/product/B00I8MJF94/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
  9. skyworm
    skyworm
    Jul 10, 2018
    4
    cambridge
  10. riddleace
    riddleace
    Nov 19, 2015
    246
    czech
    +62
    Hi, yes i added to this mix sterlin silver... with this mixtures:
    4x 2oz FolkArt Acrylic Metallic - Silver Sterling
    2x 2oz FolkArt Acrylic Metallic - Gunmetal Grey
    12oz poly
    12oz water
    and i think this will works Rust-Oleum Varathane 200261H 1/2-Pint Interior Crystal Clear Water-Based Polyurethane if it is Matt
  11. riddleace
    riddleace
    Nov 19, 2015
    246
    czech
    +62
    hi, looks at my mix...
  12. riddleace
    riddleace
    Nov 19, 2015
    246
    czech
    +62
    by the way, i have new mixtures but some resources its hard to get it... but its have amazing efect with gain about 1.4-1.5...
  13. kopmjj
    kopmjj
    Nov 4, 2009
    1,853
    48
    +82
    What about the cheaper poly linked above? I prefer not to spend that much on a poly
  14. riddleace
    riddleace
    Nov 19, 2015
    246
    czech
    +62
    if it is water based and matt, you can use it... :)
  15. skyworm
    skyworm
    Jul 10, 2018
    4
    cambridge
    @riddleace
    where can these paint be bought? also, how far away your PJ is from the screen - is there a risk of hotspotting?
    what material have you painted on?
  16. riddleace
    riddleace
    Nov 19, 2015
    246
    czech
    +62
    My projector is about 19,69ft, hotspotting is depending how far you have PJ. But i know some my friend who have it closer than me and they dont have no hotspott.
  17. riddleace
    riddleace
    Nov 19, 2015
    246
    czech
    +62
    my room
  18. skyworm
    skyworm
    Jul 10, 2018
    4
    cambridge
    thanks for that. my projector is 11.8ft away from screen, and i got a 110inch screen...windows pretty much same as you but also a french door on opposite side.
    I have an alr screen, bit reflective, and i am seeing some hotspot..
  19. riddleace
    riddleace
    Nov 19, 2015
    246
    czech
    +62
    And your ARL screen is matt or shiny?
  20. tommouk
    tommouk
    Jul 5, 2004
    333
    28
    Fleet, Hants
    +91
    Great job! :clap:
  21. skyworm
    skyworm
    Jul 10, 2018
    4
    cambridge
    sorry for late reply...my ALR is reflective, so i guess I would say shiny.
    the one you did is matt?
  22. riddleace
    riddleace
    Nov 19, 2015
    246
    czech
    +62
    yes thats is matt so he can fight more with hotspots
  23. jokako
    jokako
    Oct 22, 2018
    4
    Czech Republic
    Hello riddleace,
    I am also looking for making DIY ALR screen and I am from Czech repulic. I have pretty much the same conditions as you (bright living room, white walls and celiling, want to use PJ in daylight). I want to ask you few questions about your screen, if you have a time to share informations. Can you please send me a PM?
    Thank you!
    Petr
  24. riddleace
    riddleace
    Nov 19, 2015
    246
    czech
    +62
    Hi, PM send it... :)
  25. Squatch2001
    Squatch2001
    Nov 29, 2018
    Canada
    Hey riddleace,
    Would you be willing to share your most recent paint mix? Or rather the one that you get the best results with? Is it different than this one you posted earlier?
    1)
    6x 2oz FolkArt Acrylic Metallic 354ml
    -2x 2oz FolkArt Acrylic Metallic - Gunmetal Grey it is 667E or 667
    -4x 2oz FolkArt Acrylic Metallic - Silver Sterling it is 662E or 662
    2)
    12oz some poly water matt 354ml
    3)
    12oz water 354ml
    Your screen looks really good. Love the led effects.
  26. riddleace
    riddleace
    Nov 19, 2015
    246
    czech
    +62
    Hi, this is my curent mix what i right now use on my Diy Screen. But i already works on new formula but there is problem with paiting and one of new resources. Some more rezults i will have next year when i get back new projector... :)
  27. jokako
    jokako
    Oct 22, 2018
    4
    Czech Republic
    Hello riddleace,
    It did not allow me to send you another PM, probably because of my fresh account. Can you please tell me if is still possible to help me with buying colors or renting a sprayer gun? I was not successful with buying premixed solution, because the guy doesnt have time to send me paint to our country, so I will go with FolkArt mix. Thank you. Petr
  28. riddleace
    riddleace
    Nov 19, 2015
    246
    czech
    +62
    Hi, where are you from Petr? And yes if this will eb possible i will help you...
  29. jokako
    jokako
    Oct 22, 2018
    4
    Czech Republic
    We actually had a small conversation over a PMs few weeks ago, I am from Prague :)
  30. riddleace
    riddleace
    Nov 19, 2015
    246
    czech
    +62
    Here or by email? I am in Prague 4x days in week :)
