Fold out wall bracket for Sharp LC26A4E?
Discussion in 'Home Cinema Buying & Building' started by CraigKORE, Feb 28, 2005.
  1. CraigKORE
    CraigKORE
    I'm looking to get myself a fold out wall bracket for my new Sharp and wondered if anyone could recommend one for under 100 quid? I have seen this one in Argos which looks as if it might be perfect but I think I would like a longer arm option. Anyone have the Argos one or know of what else I should consider?
    Advice appreciated. :)
  2. blossom
    blossom
    Feb 15, 2004
    1,289
    41
    Solihull
    +14
    Craig try this:
    I bought one of these and it is very good. Easy to put up and you can have the arm longer or shorter depending on which position you decide.
    Paul
  3. CraigKORE
    CraigKORE
    Thanks for that Paul..
    Ended up just grabbing the one from Argos to see what it was like - would have done the job fine. Change of plan now though since the other half is wanting to re-arrange the bedroom, just need a decent (highish) table now. Found one in Argos and will be taking the bracket back and changing it for said table... :D
