Foggy patches on screen.
Discussion in 'LCD & LED LCD TVs Forum' started by Samari, Jan 10, 2005.
Tags:
  1. Samari
    Samari
    Hi, I was just looking for help on how to fix this LCD Tobisha T.V.
    When there is black screen you can see white patches, like fog? It looks like it's leaking in from the corners and the patches get bigger, after about half an hour they cover the screen and the colours look like they're fading?
    If you push on the parts of the screen that the fog is on, it either disappears or moves around but when you take your hand off the fog 'leaks' back in like water, is it the liquid? - the longer the tv is on the bigger it gets, but in the beginning it was a small patch that got bigger the longer the tv was on, but now it's a big patch that gets bigger.
    Any help would be great :thumbsup:
  2. strontiumdog
    strontiumdog
    unfortunately this is fairly common on cheaper lcd screens,i had the same problem on a ferguson 32inchlcd.there was fog in space on star wars.i took the tv back and spent another grand on a panny vierra and that dosent have the fog,yours does sound particulary bad.
