focus extension cable
Discussion in 'Satellite TV, Sky TV & FreeSat' started by sparkymarky, Jan 30, 2003.
  1. sparkymarky
    sparkymarky
    Dec 12, 2002
    1,071
    48
    cornwall
    +32
    just popped in to focus to get some cable so i can move my sky box, has anybody used their digital extension cable (the one that is preterminated with f connectors) ?
    1. if so is it any good/ signal loss?
    2. if this is not a good cable i noticed they also sell a digital/satellit cable on a reel at 26p p/meter. has anyone used this?
    3. does anyone know a high street store where i can get a 'female' barrel connector (i.e a double threaded connector whose ends are the same as the connector that comes out of the skybox) ?
    I can then make my own cable.
    many thanks guys
  2. Fernsehman
    Fernsehman
    Why not simply order these bits online from someone like satcure.com or satalogue.com
    It'll only cost you £2.50 for postage - probably a lot less than the petrol you'd use driving to Focus and back.
    :rolleyes:
    Fman
  3. Brian110507
    Brian110507
  4. sparkymarky
    sparkymarky
    Dec 12, 2002
    1,071
    48
    cornwall
    +32
    cheers guys, will try those companies.
  5. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    THIS will also do the trick. I have a couple in my tool box at the moment.
