charliechisholm1984
I am looking at upgrading my speakers and the Focal Chora 826 on my shortlist. They would be used in a 5m X 4m room with a relatively near field setup.
I am using a Cyrus 8+PSX-r amp which I purchased in 2004 which I would prefer not to upgrade as I enjoy the sound.
Would the Cyrus amp be powerful enough for the Chora 826 or would I need something more powerful? I've read comment about the speakers needed a lot of current.
The 826 has a reputation for being bright (perhaps overly so). I am concerned that pairing them with the Cyrus may be too much of a good thing?
Although I'm not a bass fiend the consesus seems to be that the 826 is a bit bass light. I'm currently using Wharfedale Diamond 12.3s and I find their bass is more than adequate for my room and seating position. Assuming the Cyrus has the required power would the 826s be noticeably lacking in bass in comparison?
The specs for the Cyrus 8 are:
Continuous Power 70w per channel into 8ohms
100w per channel into 4 ohms
Burst Power 340w (IHF, one channel driven into 1 ohm)
Damping factor (1KHZ) 150
Sensitivity (50w) Line 200mv
Input impedance 50kOHM (RCA)
Output voltage 380mV (pre out) S)N ratio 101dBA
