Focal Astral 16
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by IWC Dopplel, May 10, 2019.
    1. IWC Dopplel
      IWC Dopplel
      Sep 11, 2008
      4,041
      134
      BATH
      +533
      interesting I heard the very new focal Astral 16 at the Munich show....
      A good comparison as they played the two front focal speakers driven by the naim atom and then the 7.2 system and whilst it moved some air I wasn’t overly impressed tbh
      Also odd unit as it has class d amps built in for 12 channels and 4 processor out. Evidently the unit is based on a storm and will be near £20k
    2. Jamie
      Jamie
      Jun 27, 2007
      5,369
      2
      Harrogate
      +1,395
      Does anybody find it weird there's an even number of channels? 12 amplified channels seems a bit weird when one the most common layouts might be 7.4.2 so 11 channels of amps required
    3. themovierooms
      themovierooms
      Well-known Member AVForums Sponsor
      Aug 6, 2013
      1,006
      117
      Edinburgh
      +858
      Focal are going to send me one of these to have a tinker with when it lands in the UK. I hope to write a detailed summation once I have it and will pop it in here as available.
    4. IWC Dopplel
      IWC Dopplel
      Sep 11, 2008
      4,041
      134
      BATH
      +533
      I’m sure it’s better than the demo suggested at the Munich show when they swapped from a naim uniti atom driving the same speakers which sounded dynamic and weighty to the Focal which sounded somehow a little hollow and loud but quite brash with for me a lack of real drive. This whole processor ‘thing’ is quite tricky !
    5. Phil Hinton
      Phil Hinton
      Editor Staff Member
      Jan 18, 2001
      10,500
      3
      +9,273
    6. Scott_Mac
      Scott_Mac
      Jul 4, 2005
      6,185
      2
      2
      Bromsgrove
      +660
      Personally i think it's great that they're including amplification... i do find it a bit odd. If you're spending that much surely you're likely to already have power amplifiers?
      For me it would be perfect though as I don't have space for more than one box. Just a bit out of my price range though :D
    7. Ringnut
      Ringnut
      Jun 8, 2004
      1,695
      116
      Surrey
      +1,928
      A £20K AVR? :eek: I think if I was paying that much I'd prefer my amps well away from my pre/pro stages.
    8. 494930
      494930
      Dec 15, 2016
      1,491
      116
      Lisburn
      +1,345
      Even worse, it's a £20k AVR that doesn't even allow you to connect external amplification :eek: I can't see there being much of a market for this.
    9. leftygolferuk
      leftygolferuk
      Jul 1, 2011
      14
      Essex
      It is just a Storm unit rebadged, I don't believe there are any technical difference from the Astral to the Storm AVR unit (forgot the model number, but its also not on their website anymore, so maybe Focal bought the last load from them?)
    10. IWC Dopplel
      IWC Dopplel
      Sep 11, 2008
      4,041
      134
      BATH
      +533
    11. Rambles
      Rambles
      Jul 14, 2004
      10,389
      167
      UK
      +2,122
      The specifications say that is has a 1000 watt power supply. Presumably it's class a/b so half is lost to heat, leaving 500 watts to power 12 speakers for £20k. Hmm.
    12. flax
      flax
      Nov 6, 2015
      26
      16
      Milan
      +41
      Not a/b, I read the following:
      "Utilizing a Class D Pascal amplifier, 12 of the channels are amplified (200W at 8 ohms) and 4 are pre-amplified acting as dedicated audio channels which feature Digital Signal Processors for filtering, equalisation and bass management and culminating in balanced XLR outputs"
