Foam or triple flange for Shure E3c
Discussion in 'Headphones, Earphones & Portable Music' started by clivem2, Aug 23, 2005.
  1. clivem2
    clivem2
    I have Shure E3c earphones, I find the foam rings are easily the best in my ears compared to the standard flex sleeves. I'm wondering about the optional triple flange in-ear thingys. Of course everyone's ears will be different so I really need to try the option, is their a general concensus on foam vs triple flange? (my ears seem to need medium size flanges).
  2. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    Just my opinion from things like the Etymotics(which I have) and various other earphones....you really have to just find which gives you the best compromise for fit and sound quality....dont worry about a consensus,when as you rightly say,everyone's ears are different.
  3. clivem2
    clivem2
    Agree with what you say, the only problem is that I have to buy the triple flanges and I'll know within seconds if I've wasted my money.
    I suppose though the triples have one thing in their favour, if I use the E3c's for a short period (ie a short flight) and need to take them out to listen to annoucements then this is easier with the triples.
  4. pjskel
    pjskel
    Oct 12, 2004
    2,676
    83
    UK
    +124
    Foam - more isolation than the silicon flanges, triple or not.
  5. clivem2
    clivem2
    It is the isolation that's important, with foam I'm transported to a different place by the music. If the triple flanges don't do this then it's foam for me.
  6. JayCee
    JayCee
    Jan 20, 2004
    20,205
    Lanarkshire
    +1,931
    Agreed....you have to compress the foam between your fingers first, insert them in your ears and hold them for about 25-30 secs.....they then expand to fill and seal your ear cavity giving great isolation and much better bass than any of the other sleeves.
  7. Big Kev
    Big Kev
    Aug 19, 2003
    291
    +8
    I use the triple flanges with my E4c's and they're pretty comfortable in my opinion and form a good seal.
  8. quinnmar
    quinnmar
    Jul 25, 2005
    317
    +39
    I currently use the smallest buds that came with my E4c earphones.
    I'm keen to try the triple flange buds but they are too big. I read a while back that you cn cut these down to size.
    Does this mean I need to cut off the bigger flanges and trim down the nozzle a bit?
  9. Big Kev
    Big Kev
    Aug 19, 2003
    291
    +8
    According to the leaflet that came with the E4c's, it states, word for word:
    If desired, the sleeve nozzle may be shortened. Use sharp scissors to carefully trim the nozzle to the desired length.
    I suppose you could cut away the bottom flange, but unless you've got some spares, I wouldn't advise it.
  10. kwbarrett
    kwbarrett
    I personally own the E3C and use the triple flange sleeves. I find them both easy to insert and very comfortable. The isolation is outstanding. My lawn mower was reduced to a simple whisper. I did cut the tube down a bit on mine. It's now flush with the last flange. this makes them much less bulky and a little more comfortable. In my opinion they isolate much better than the foam.
  11. PKblue
    PKblue
    Jan 24, 2003
    41
    I have the flange set - mine comes with 2 and 3 cone flanges.
    I have tried using them, and sometimes I think they're great, but they just don't sit consistently in my ears, and when the seal isn't quite right they are not very good sound. Obviously other people prefer these, but for me I rarely use them.
    I haven't been very successful with the foam either - admittedly I haven't tried holding them in for 25secs before releasing (I do squash the foam first).
    I should perservere, for I miss the bass impact of the much cheaper Koss Plugs.
    PK
