FMJDV27 Component Outputs Question?
Discussion in 'Arcam Owners' Forum' started by KBDVD, Dec 4, 2003.
  1. KBDVD
    KBDVD
    Aug 25, 2002
    714
    Hertfordshire
    +6
    Hi All,
    A quick question,
    Are the duel Component Outputs on the FMJDV27 / DV27+ "always on"?
    By this I mean, if I were to connect the Progressive set to a Plasma panel and the interlaced set to a DLP Projector, would I get an image on both simultaniously or is it neccessary to select either Progressive or Interlaced output from within the DV27's internal menu settings?
    Thanks in advance for any help.
    Best Regards,
    KBDVD.
  2. robocop
    robocop
    Oct 16, 2000
    646
    Old Detroit a.k.a. Chippenham. Wilts
    +23
    Yes, they are always on and can be viewed at the same time.
