FMJ DV27 component switching prob
Discussion in 'Blu-ray & DVD Players & Recorders' started by mega_stream, Dec 27, 2006.
Tags:
  1. mega_stream
    mega_stream
    Aug 29, 2006
    56
    Just tried to connect my DV27 out via component through my Denon 2307 amp, have configured the video sources for component on the Denon - get no picture from the DVD though.
    Have even tried the straight component out from the Dv27 - still no picture, both outputs work fine direct to the TV.
    Anyone know if the DV27 has any problems running through an amp for video switching?
    TIA
  2. webhammer
    webhammer
    Jul 6, 2006
    228
    28
    Indianapolis
    +22
    Hi quality video might be set on SCART rather than component, check the SETUP menu on s-video or composite.
  3. mega_stream
    mega_stream
    Aug 29, 2006
    56
    Tis' set to component, works fine if direct to TV, only when through Denon I get no pic.
  4. texasboy
    texasboy
    Sep 16, 2002
    390
    +15
    Is the component input you are using on the 2307 assigned correctly?
