FM tuning on T32
Discussion in 'TAG McLaren Audio Owners' Forum' started by ttagster, Jul 20, 2005.
  1. ttagster
    ttagster
    Feb 24, 2005
    74
    Having just purchased a T32 I installed an outdoor DAB antenna and can receive all the DAB stations in my area. :D
    However, on FM I initially tried an outdoor omni aerial and could not receive anything. I then changed this to a 6 element directional aerial. At first this also gave no joy but then switching to DAB and then back to FM the signal was now at full strength and I could receive all the FM stations. Subsequently switching back to DAB and then to FM I lost the signal again. Since then I have not been able to get the FM signal back. :(
    Any suggestions or is the T32 FM section to blame. :confused:
  2. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    Have you selected the correct FM input aerial as it can have two, one normally for a standard FM aerial and the other for a cable based feed...??
  3. ttagster
    ttagster
    Feb 24, 2005
    74
    If anyone is interested. The problem was a break in the 75 ohm coaxial cable half way along its' length which was intermittently making for short periods.
    Everything is fine now that I have replaced the cable. :clap:
  4. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    :rotfl: :rotfl: :rotfl:
    Cheapest fix you will ever have as well.......
  5. DanielB
    DanielB
    May 27, 2004
    158
    Switzerland
    +12
    I would not send the cable to IAG for repair - it could take months (to locate)until they will repair it. :devil:
