FM connections to Pioneer system
Discussion in 'Home Cinema Buying & Building' started by ali13B, Nov 8, 2003.
  1. ali13B
    ali13B
    Dec 16, 2002
    26
    I wonder if anyone can offer some advice.
    I'm getting fairly poor radio reception on the supplied 'single wire' antenna provided with the dvd player originally, so decided to buy a proper antenna with booster.
    But, nothing seems to be able to fit the connector at the back of the machine. It appears to be a normal female receptor, but all male connectors are of an identical outer ring size, so will not fit together.
    The machine is a pioneer 303. Can anyone suggest an adaptor that i might require, or is it a problem with the style of the dvd player???
    Many thanks
    Ali
