fly back problems on a barco data 800
Discussion in 'Projectors, Screens & Video Processors' started by joedjemal, Jun 19, 2001.
  1. joedjemal
    joedjemal
    Hello.
    I recently bought a second hand Barco Data 800. It's working well except for a problem on the red gun. There's an obvious fly back line crossing diagonally several times up the screen and the area not blanked that doesn't contain a scource is tinted red.
    Does anyone know how to correct this? Better still, does anyone know where I might be able to find a copy of the manuals?
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    joedjemal
    When the projector has no source does it do the same?
    Does it still do it with the brightness turned down?
    Looking down the lens is the light constant or flickering?
  3. joedjemal
    joedjemal
    Hi. Thanks for replying.
    With no source the fly back line is still there, as it is with the brightness turned down and it flickers with no source. (I'm not sure what you mean by flicker the fly back line jitters but it's constantly visible)
    (The red gun is visibly brighter than the others with no source)
    Thanks for your time.
    Joe
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Sorry to say this but I think your red tube has gone. It could still be the end stage.
    Don't take this as gospel get it checked out.
