Fluorescent Dye
Discussion in 'Desktop & Laptop Computers Forum' started by Dick Scratcher, Jan 27, 2003.
  1. Dick Scratcher
    Dick Scratcher
    Ninja PC project needs a touch of glamour. My 'Wet And Chilly Chips' watercooling rig could do with some fluorescent dye in the pipes to attract the ladeez! Anyone know where I can get hold of some? I'd prefer to buy in the UK if possible!
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Look up any major chemical supplier and you can get something if you are lucky. Most are unlikely to sell in the amount you want (ie. a gram of the stuff is likely to do you 5 times over!). The quantity you want you just need to find someone friendly and they would give it to you.
    ad
