Fluffy Reds on Pioneer 433MXE
Discussion in 'Plasma TVs Forum' started by Darbyweb, May 16, 2003.
  1. Darbyweb
    Darbyweb
    Mar 18, 2003
    58
    Bedfordshire
    I've noticed with text and certain red images i get pixelation around red images.
    Last night someone was holding a red book at an angle, the top of which ran at 30degrees across the screen, this edge was totally fluffy..
    It only seems to be with Orangey/Reds ??
    Any suggestions
    Dean.
  2. CarlB
    CarlB
    Jan 8, 2001
    1,300
    Cambridgeshire
    +226
    Sounds like the chroma bug. Not sure which DVD player you are using but many players have a problem upsampling red in the image, which results in the pixelisation and banding you are seeing.
    I can't be certain, but it definitely sounds like the bug. Try a search for your player, there are lots of posts about the bug on this forum.
  3. Darbyweb
    Darbyweb
    Mar 18, 2003
    58
    Bedfordshire
    Thanks - this was actually via the Sky Decoder
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    Sky decoders can have chroma issues. It's a facet of the mpeg decoder chipset used in the product.
    I am not sure if this is a chroma bug issue. Doesn't sound too nice though.
    Gordon
  5. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    As GordonF says, it sounds like the Chroma Bug in Sky digibox decoder.
    This excellent link has detail about Chroma Bug http://www.hometheaterhifi.com/volume_8_2/dvd-benchmark-special-report-chroma-bug-4-2001.html it also appears in US DirecTV decoders too. Scroll down and see "Figure 7", this is what typically happens with Sky digital unless you have a chroma filter.
    Some processors like iScan Ultra, and the Key Digital kit Gordon sells, fix this problem with chroma filters.
    StooMonster
  6. PVR
    PVR
    Oct 23, 2002
    181
    16
    Nr Gatwick
    I had exactly the same problem, tried the iScan Ultra and there was no difference in result on the Pioneer 433 MXE.
    I am waiting for a solution for exactly the same problem as well, so am interested to hear if anything comes up.
    Regards,
    PVR
  7. Darbyweb
    Darbyweb
    Mar 18, 2003
    58
    Bedfordshire
    Looking at that link - those images are exactly what i'm getting with the Reds.
    I've read a couple of posts about the iSca, first thing i noticed was the price :( - second was the lip sync problem, which i've noticed with any other processing introduced.
    I guess its something i'm going to live with - i shall whack in a DVD to see if i get it on them - though i dont believe so
    Dean.
  8. briandzo
    briandzo
    Dec 12, 2002
    373
    19
    Newbury , Berkshire
    snap i get it too...same kit.
    it seems if you turn the contrast down a little
    it may improve.
    also
    what 'power control' option do you have
    mode1 mode2 or standard.
    this also seems to make a differance.
    mode2 gives the best results for me.
    although this has impact on overal picture.
    where it just aint bright enough.
    there is a fair amount of setting up.
    remember theres a contrast setting with the sky box.
    what settings are we all using ?
    Brian..
