Flower Cooler
Discussion in 'Desktop & Laptop Computers Forum' started by gallus23, Nov 7, 2003.
  1. gallus23
    gallus23
    Jun 30, 2002
    65
    Godmanchester, CAMBS
    Hi all,
    I'm interested in the LMP case but I'm wondering if any of you chaps are using it with a flower cooler . . ..
    Ta.....
    G.
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    yep fine here no problems fitting it in the case
  3. Kramer
    Kramer
    Assume there shouldn't be a problem - loads have the Flower cooler & that case is quite popular too.
    Mr. D has confirmed.
    The Flower coolers are quite heavy though so moving should be treated with great care.
  4. TEK
    TEK
    Guess it depends a little on your motherboard configuration but loads of space in my LMP mate :)
    Only problem I've ever had with other machines has been on one Soyo Platinum where it was a bit tight with the RAM in place but this was board layout problem and nothing to do with the case
  5. gallus23
    gallus23
    Jun 30, 2002
    65
    Super . . . full steam ahead then....
    Cheers Chaps..
