Hi all
Based on feedback from othe forum members, I decided to take the plunge this week and purchased a FloppyDTV & Dragon/TREX CAM from the guys at firedtv.com - great service and great guys if anyone want to use them!
Ive done all my homework through the other threads, so know what to expect, but for some reason, Ive currently got myself in a bit of a pickle regarding the setup, and Im looking for some advice as to how to get it all setup. My end goal is to have Sky UK running through MCE with the EPG working for the Channels I would like to use probably around 150 in total Id say, including all the Movie Channels, Sky One, and pretty much all the premium content from Sky.
Im currently running MCE2005 with all the updates required for FloppyTV to work correctly.
So, heres the setup process I went through last night;
Floppy TV & CAM setup;
Installed Floppy TV to PC fine
Installed Floppy TV drivers fine
Installed CI programmer fine
Updated TRex firmware with Sky Box serial number fine
Initial Scan setup;
Scanned for channels fine 100s of channels were thrown out including the Sky premium channels perfect I thought
Then I decided to tackle the EPG which is where it all went wrong .! Heres the process I went through as per posts in Sky/MCE thread;
Initiated TV Guide fine
Entered home postcode fine
Selected closest transmitter Sutton Coldfield fine
Scanned during the scanning there were initially around 160 channels found, but when the searched reached about 80% it reverted to 0 channels found and then prompted that nothing had changed.
Entered registry and updated EPG Headend with a known Sky one - fine
Then went into Guide and downloaded latest guide info - fine
I then went into edit channels, and MCE hung for a while, then threw out over 7500 channels! Looking closer it seemed like there were multiple entries for the same channel, ie, 20xMTV and 25xUK Gold.
There were also some channels now missing, including all variations of Sky One.
Furthermore, when I save the channels, the premium ones are not available during live TV. Its also not possible to remove multiple entries of the same channel via the restore channel defaults option.
It all seems to have gone pear shaped when I tried to use the EPG, so I think Im at the point now where Ill be happy to start from scratch with the channel setup.
To do this, I was hoping anyone could offer some guidance regarding the process I went through above was anything missing or incorrect? Am I making any mistakes along the way?
Here are the key questions I think I need to answer;
Firstly, putting it all back to square one;
Is there an XML file somewhere that details all the found channels?
If so, can I modify this or delete it and start from scratch?
Is there something like a master reset action that can be performed on TV settings to start from scratch?
I think all of the above process I did last night is correct can anyone confirm? Im assuming its correct as I had it all working before I started playing around with the guide!
EPG setup;
Can anyone give a quick overview of the hierarchy of the Guide within MCE? Does the edit channel list only provide details of channels MCE thinks would be there from the guide?
Am I correct in performing the headend change last in the whole process?
Am I correct in the process I was doing earlier, ie, turn on guide, scan for channels, update headend, update channels, edit channels, then add listings to channels?
Apologies for the long post, Ive tried searching through the Sky/MCE thread, but its a bit of a nightmare to put everything together in a cohesive picture I suppose thats the only downside of having a thread over 70 pages long!
Anyway, if anyone could offer some guidance or advice, that would be great!
Pete
Initial Scan setup;
EPG setup;
Pete
