50-60cm from the walls is really a lot... In the advice of Q Acoustic they talk about 20cm.Around 50-60 cm from the walls, or the bass can get boomy. Still this is room independent.
The room (the living room) is 27square meters.
It's 5,97 x 4,43I don't think you'll need 60, but 20 would likely be too little. I mean space behind and size if room. However, I don't think 27m squared is too small for these, I think you'd be ok (assuming it's 5x5 or 6x4 approx, not 9x 3 or very weird shape)
I might be inclined to look at the 3030i on a nice set of stands also
Do you mean space behind the speaker, such as distance from the wall, or a large enough room?
Seems like a regular not too small room. I think you'd be okIt's 5,97 x 4,43![]()
Agree with the concept 40s.Hi.
I'd say the same thing to anyone with a ~£600 budget. Buy stand mounts. Your money puts you in the next quality bracket up, whereas that money for floorstanders is still only enough for budget ranges.
One exception would be if you could stretch to £700 and get QA Concept 40's.
