Floorstanding Reccomendations
Discussion in 'Home Cinema Speakers' started by gregmcquaid, Jul 26, 2005.
  1. gregmcquaid
    gregmcquaid
    Aug 20, 2004
    279
    Bristol
    +10
    I am currently looking to replace my speakers with a pair of decent floorstanders, i have been looking around but havent been able to make a decission becuase im not sure which ones will suit me best.
    I was wondering if someone could reccomend a floorstander to me that is around 300-350. I am currently runnning a yamaha amp, although i am going to upgrade this as well soon.
    Thanks for the help
    Greg
  2. Timmy C
    Timmy C
    Oct 10, 2003
    5,181
    +398
    Monitor Audio silver series can be found going cheap in various places including Sevenoaks branches at the moment. I think they've just been discontinued but don't let that put you off!
  3. gregmcquaid
    gregmcquaid
    Aug 20, 2004
    279
    Bristol
    +10
    Ok i have narrowed it down to two speakers.
    I am looking at either the MA Silver s5 at 299.99 or MA Bronze B4 at 314.99, which one do you think is better?
    Greg
  4. Timmy C
    Timmy C
    Oct 10, 2003
    5,181
    +398
    If you go to Richer Sounds Ireland website (http://www.richersounds.ie ) you could get the Bronze B4 for about £275 delivered but although I've not heard either, my gut feeling is the Silver s5 will give you a better sound as after all they did retail at about £450 originally. Seeing as you're considering a new amp in the future I bet if you choose well you'll end up better off with the Silver series.
    Hopefully someone who's heard both will give you their thoughts.
