floorstanding or book shelf for me?
enerlevel
hello everyone, i need some advice on my setup.
i have a Yamaha V473 which is about 80x5. and it can take uptill 6ohms.
for my surround and center i have the Bose acoustimass 6 setup along with the Base module.
i have been looking to replace my fronts with something more powerful for music.
i am on a budget roll, therefore want something really cheap and good, hence looked into the used market and this is what i found
1) MS (MORDAUNT STOP) VS-300 floor standing (6 ohms) £60
2) Tannoy 611 MK 1 - £100
3) B&W 602 Bookshelf - £`120
which one of these would be a better buy and good for my setup?
thanks
Soundmangt4
I had a set of Tannoy 605's from the same range as the 611's and loved them. If they are in good condition, then that's what I would go for personally.
KelvinS1965
Whichever one you like the sound of best in a demo. :) Possibly that the bookshelf might be a better buy since a cheap floorstander may just sound boomy in an effort to impress with 'bass'.
Also, using any of those with a Bose centre will give a poor result, so bank on buying a matching centre if you want any semblance of a front soundstage. Even different sized speakers from the same range can sound poor when mixed, let alone two very different types of speaker.
enerlevel
thanks for the reply, i want to use the speaker mainly for music. so i will be using them for 2 channel stereo operations mostly.
for movies, i might just completely lower the volume level so that i can achieve the right mix... about the centre yes i might change it but later on.
all these speakers are second hand so having them to listen with the same environment and same amp etc is very difficult....
Rocky 4K, Creed 3 and boxing movies, Shazam 2, 65 trumping Jurassic World Dominion, + Picard & Mando
