Floorstanders on Laminate floor
Discussion in 'Home Cinema Speakers' started by mr jones, Sep 6, 2007.
  1. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    im about to lay a laminate floor in my living room and im trying to find the best way of isolating the speakers from the floor (currently on spikes), obviously the spikes will damage the floor which im not keen on doing (paying quite a bit for the floor!). the person in the hifi shop mentioned isolation pads but i cant find anything on the net about them.
    does anyone know of such a product or can anyone point me in the right direction to solve my problem. my speakers are Celestion F30's if thats any help
    thanks in advance
    jamie
  2. trevor g
    trevor g
    hi, try this, two pieces of mdf or hdf fibre board at least 25mm thick and
    possibly the floor colour slightly larger than the speaker base, blue tac
    these to the floor ( it wont mark the floor) and place spikes on these.
    mdf or hdf is very dense and inert. regards trevor. ps a friend of mine
    sorted his big missions using this method.
  3. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,253
    Milty Polipods at £16 approx for eight. Or Milty Foculpods which are good for up to 10Kg at £16 for four.
    Can't scratch the floor and as they are soft they they balance out any uneveness.
    They're made of Sorbothane which is an extremely efficient isolator. It's a bit odd having wobbly loudspeakers. It seems counter intuative after years of being told spikes isolate (they don't), but because the resonant frequency of the wobble is so low, the speaker is still effectively rigidly supported at all audible frequencies.
    They work extremely well under DVD and CD players too.
  4. gadget boy
    gadget boy
    Dec 29, 2006
    163
    +15
    Cheap and cheerful trial is to place a 5p coin under each spike.
    I have a set of Kef floorstanders which I have on small rubber hemispherical feet. These were supplied with the speakers (as well as the spikes). Seems to work fine and they don't mark the semi solid flooring.
    GB
  5. CLIVEEDWARDS
    CLIVEEDWARDS
    Feb 17, 2005
    153
    +6
    I use RDC cones under my speakers on laminate which made a huge improvement in sound over the felt pads I was using before.
  6. Purbs
    Purbs
    Sep 3, 2007
    87
    Not sure if this is the best solution sonically, but it certainly protects the floor and looks OK:
    1p coins backed with the sticky-backed stuff you can buy for protecting the floor from chair legs etc.
    I've previously used copper coins placed directly onto floorboards, but later learned that this stains the wood.
    I imagine 1p/2p coins will blend in a bit better than shiny silver 5p pieces.
    Cheers,
    RP.
  7. Deldrummer
    Deldrummer
    Nov 5, 2005
    33
    Glasgow
    +5
    I used the felt sticky things that you would normally use with the castor cups that you use to protect laminate floors from furniture legs, wheels etc. Just use the felt pads under each speaker spike. I left the backing paper on the sticky part so they don't stick to the floor. I managed to get small round felt pads about the size of a 10p piece from B&Q.
    Picture attached for refererence.
  8. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    cheers for all your advice people, i think ill try a few of the suggestions and see which one isolates the best :D
