Floor mats in cars
Discussion in 'Motoring' started by Ian J, Mar 25, 2006.
  1. Ian J
    Ian J
    Aug 6, 2001
    25,639
    +4,906
    Floor mats in cars serve an odd purpose which I have given more thought to this week as I have been out and about looking to replace my car and have therefore looked more closely at other car interiors than I normally would.
    Many people will use car mats to protect the carpets and indeed many of the cars that I have looked at have carpets that are like new as they are protected by mats. When these cars are about 10 years old they must be coming to the end of their useful lifes as the mechanical bits are tired and the bodywork is starting to rust and the paint peel but the carpets are still in the same pristine condition as when the car was brand new.
    My guess is that cars go to that great scrapheaop in the sky with carpets that have still never seen the light of day.
    My new second hand car also has mats over what seems to be brand new carpets so will I do the sensible thing and chuck them away - not likely, I don't want dirty footmarks all over my pristine carpet :D
  2. lynx
    lynx
    Jan 20, 2002
    4,653
    It always rains.
    +302
    Ian,are you aware of boot liners that serve a similar function in the errr boot. Custom made liners keep most of the available space and should keep the boot as good as new for years.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,639
    +4,906
    I could get a purpose built cover for the whole car with holes cut out for the windows and none of the exterior would ever get dirty either
  4. rhoamish
    rhoamish
    I thought car mats were originally intended to protect your shoes?
    It's also a lot easier to fit new mats than it is to fit new carpets, which are often shaped to fit the whole car floor. Mammoth job to change, and expensive too!
  5. Londondecca
    Londondecca
    Dec 21, 2003
    2,105
    +108
    Even with mats it is still useful to clean the carpets. It is easy to do with the right tools ie wet/dry vacuum cleaner but very good results can be gained with some basic items such as a upholstery brush and some towels, it will just take longer.
    Giving the interior a damn good clean can transform even the dirtiest cars into something which is very pleasant to sit in. With periodic maintenance cleaning it is easy to keep the interior looking great.
    This is a great article on cleaning the interior including carpets http://www.guidetodetailing.com/articles.php?articleId=11
  6. Peridot
    Peridot
    Aug 24, 2004
    2,995
    Newport, South Wales
    +293
    Floor mats can be dangerous too believe it or not. In a previous car I had heavy rubber 'universal' mats with various grooves around the edges allowing you to trim to the size and shape of the footwell.
    Once when accelerating hard away from a toll bridge exit the accelerator pedal jammed down, which was not a particularly pleasant experience. What had happed was that the bottom of the pedal metalwork had become jammed in the groves of the mat, holding it down. A couple of kicks at the pedal freed it before any damage was done, but when I figured out what had happened it was goodbye to the mats.
  7. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    A couple of cars ago I had the (then new on the market) Lexus IS200.
    It had a recall soon after I got it to fit an offisde front floormat that was was properly anchored.
    This was to prevent the possibility of a "stuck pedal" problem as mentioned by Peridot.
    Chris Muriel, Manchester
  8. lmccauley
    lmccauley
    Oct 24, 2000
    3,668
    Newcastle
    +422
    When I drove in america, I saw some sporty cars had "car bras" which covered the front of the bonnet to prevent stone chips. Talk about making the car look silly!
    Cheers,
    Liam
  9. shahedz
    shahedz
    Apr 26, 2005
    11,064
    +1,953
    i hate those things,
  10. Stinja
    Stinja
    Aug 13, 2003
    12,826
    163
    +4,187
    I kinda get your point, but it's the difference between selling a car and keeping a car. If you ever intend to sell, then a better interior will make punters think its been better looked after.
    The other point I can see is for "dirt" which isn't so easy to clean: dog poo, oil, chemicals - if spilt in your car they can be annoying to get out of carpet. If you have a mat, you can throw the mat out :confused:
    But you've reminded me to make a thread now... ;)
  11. Kebabhead
    Kebabhead
    Mar 7, 2006
    7,157
    +508
    Universal ones can be
    My mats were from the dealers and they had plugs you screwed into the carpet on the drivers side and attached the mat to them to stop it sliding around
    Unfortunately now there is a small hole in the drivers mat due to heel wear :rolleyes:
  12. bearman3784
    bearman3784
    Dec 18, 2007
    5,813
    Hitting the Eastside of the LBC
    +1,649
    ditto, dont wanna spend £50 on mats :(
  13. FZR400RRSP
    FZR400RRSP
    Mar 5, 2007
    32,038
    Aberdeen
    +10,374
    Ebay is a good source of floor mats.
    You can get fitted ones on there, with the appropriate holes for securing to the cars floor lugs.
    I've bought for Renault/Ford/Audi.
    Usually as spares, rather than replacements.
    They're not as good as OE, but they're nowhere near as dear either.
    Under £30 usually gets you a full set (excluding daft logos etc.)
  14. mij
    mij
    Jan 14, 2002
    3,884
    London
    +999
    Slip on driving shoes (slippers) left in the car are what you need :)
  15. ufitsy
    ufitsy
    Aug 18, 2004
    3,280
    103
    Midlands
    +353
    One of my neighbours had no mats in his car, after 7 years it failed the MOT as the floor had rotted all the way through on driver and passenger sides.
    I can only assume it was the wet salty water from shoes soaking through the carpet & just sitting damp for months over the winter.
    Would rubber mats have stopped this?
  16. FZR400RRSP
    FZR400RRSP
    Mar 5, 2007
    32,038
    Aberdeen
    +10,374
    I don't care how practical they are, I hate rubber mats in a car.:nono:
    I just think they ruin the look of the interior, making it look like a van.
    I use cloth mats all year round, no problem at all, have done for decades.
    I can see why farmers/builders would use rubber mats though.:thumbsup:
  17. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
    Wow this is an old thread its dated March 2006.
  18. Ian J
    Ian J
    Aug 6, 2001
    25,639
    +4,906
    It took you over four years though :rotfl:
  19. shahedz
    shahedz
    Apr 26, 2005
    11,064
    +1,953
    It gets worse than protecting carpets. i have a friend who doesn't even want to mark the original mats supplied with the car so uses horrible universal rubber things. Doesn't fit at all and looks terrible.
  20. Jay J
    Jay J
    Apr 18, 2009
    908
    43
    Teesside
    +195
  21. Stinja
    Stinja
    Aug 13, 2003
    12,826
    163
    +4,187
    Yep :smashin: what can I say, I'm a threadnomancer... :rolleyes: but why waste a good discussion thread if it's still relevant.
    I guess it's aesthetics vs practicality? Totally agree on ugly rubber mats which get caught under the clutch or brake pedals :suicide: but I'd argue a mat on top of the base carpet isn't a bad thing if done well, and just stops that wear and tear. Then when you sell, you can pull all the mats out, and it'll look nicer.
  22. shodan
    shodan
    Dec 11, 2001
    12,089
    shoeburyness
    +7,624
  23. rousetafarian
    rousetafarian
    Aug 17, 2007
    23,657
    2
    NW
    +15,602
