Floating wall
I am going to go ahead with my floating wall!
I need to know which screws/bolts should i use.
I want to hang the bracket to the floating wall like groove has but need to know which bolts/screws i should use to fix the bracket to the wall
EDIT: decided against floating wall in the end (too much work for a student lol)
groove
Can't you sue the same as I did ...pictures are in my thread.
Alternatively if you cant go through the wood into the wall as I did use the biggest mutha Coach Screws you can into the timber , and make sure the timber is secured securely to the wall.
