Floating shelves for DVD player etc
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by davegtt, Feb 11, 2005.
  1. davegtt
    davegtt
    Dec 22, 2004
    112
    Hi peeps, Im after 3 or 4 shelves, seen them before but now Im ready to buy I cant find them anywhere but what Im after is a shelf that will hold the DVD player and has like a trunking part built to it where you can add another shelf on top or not if you wanted to. anyone got any pics or links etc? thanks
  2. tonycommander
    tonycommander
    Nov 1, 2004
    2,038
    Malvern
    +152
  3. davegtt
    davegtt
    Dec 22, 2004
    112
    ahhh yes its something along them lines thanks, although the ones I saw was off a reasonable price ;) i.e. £30 per shelf was more in my price range ;) £700 for shelving is way too steep, rather buy a mini plasma for the bedroom :D
  4. davegtt
    davegtt
    Dec 22, 2004
    112
  5. BIGMAX
    BIGMAX
    Jan 11, 2005
    745
    +18
    Dave,
    Did you get those Vogel stands ? - can the equipment be placed directly onto these stands or do you need something like a glass shelf put on first.
  6. theo cupier
    theo cupier
    Sep 18, 2004
    1,649
    63
    Amersham, Bucks
    +113
    Dave
    B&Q do something very similar. It's modular and has a cable tidy unit. Each shelf is an 'H' shape, rather than a V and is adjustable for depth and width on each cross bar (I think) and holds up to about 15Kgs.
    I'm afraid i can't find the item on the B&Q site at the moment, but they were about £20 per shelf which is a bit less than the ones you found.
  7. sniffer
    sniffer
    Jun 5, 2003
  8. theo cupier
    theo cupier
    Sep 18, 2004
    1,649
    63
    Amersham, Bucks
    +113
    sniffer - that's the badger! :D
  9. davegtt
    davegtt
    Dec 22, 2004
    112
    Hi, thought this thread had died. I havent bought any shelving as yet. stuggling to find something good enough. we've seen them shelves at Homebase, fairly convincing. not 100% yet. we are waiting on a new sofa as the woman has gone off the idea of mounting them on the wall now. still not even got the plasma on the wall yet :( getting annoying now
  10. vancouver
    vancouver
  11. davegtt
    davegtt
    Dec 22, 2004
    112
    That is similar to what Im after, thank you very much :)
  12. imichael
    imichael
    Nov 5, 2004
    209
    16
    West Sussex
    I've ordered the Vogels 2 weeks ago, but stocks seem a bit short. They are expected end of next week, I'll post up my opinion when they arrive
    Ian
  13. Pieman1972
    Pieman1972
    Jan 6, 2005
    58
    I ordered two Vogel stands and 4 cable covers a few weeks back - they arrived after about a week - however we have had a small problem as I ordered all silver.......I received 1 silver and 1 black, unfortunately when the return was submitted I received the new one by return - ALSO BLACK !!!!!!!!!!!!!!!!!!
    Apparently the Silver one has now been sent (and heard from home that they have attempted delivery......) I will hopefully be able to get them up over the weekend and let everyone know.....
    However - in answer to previous enquiry - no glass shelf is required
  14. imichael
    imichael
    Nov 5, 2004
    209
    16
    West Sussex
    Finally had the time to mount the Vogel stands over the weekend. They are a doddle to install, and are very sturdy. The only problem is the depth as the cable tidy system is directly in line with the component ports on the rear of my Yamaha amp. So new cables needed (also there is not enough space in the cable tidy for 4 full spec component cables).
    The acid test is my wife is happy and the 4 year old hasn't tried to climb them yet, so I'd recommend them.
  15. mattcafc
    mattcafc
    Mar 11, 2007
    457
    +19
    Bumping an old thread.
    I'm looking for some floating shelves (Either glass or white) to store my Sky box and WDTV next to my wall mounted panny. I also want to put some leds under it. Does anyone have any suggestions for shelves, as they seem few and far between these days?
  16. richardkingsley
    richardkingsley
    Mar 29, 2013
    Just received the parts myself to put up 3 floating glass shelves. Bought brackets from company called peak rock uk and had some 6mm glass shelves made, drilled for cables and toughened at a local glass company who also polished edges
    3 brackets came to £66 and glass was £40.
    When I put them up I will post photo but need to get the chase that was cut into solid wall for cables repaired first this week.
    Hope that helps
    Richard
