flip down tv signal
liladz
hi, just brought flip down tv with freeview for kitchen, it has 2 connections - dvb-t one in and the other out, i dont have ariel socket in kitchen so brought portable one, it will not receieve a thing the plug will fit into the in connection, do i need somethin for the other one? or any ideas? thanks
Starburst
Welcome:)
The obvious thought is that you are simply not receiving a signal of sufficient strength via the indoor aerial in the kitchen, placement is critical for an indoor and well quite frankly the performance can vary from day to day hence the long term advantage of a high mounted fixed rooftop aerial.
Try the aerial and TV in another location, I am of course assuming you already do or know you should be able to receive the Freeview broadcasts.
fernandez
hi, just brought flip down tv with freeview.... i dont have ariel socket in kitchen so brought portable one, it will not receieve a thing the plug will fit into the in connection, do i need somethin for the other one? or any ideas? thanks
The portable aerial you bought will be fitted with a standard co-ax plug and evidently the TV has a non-standard socket.
An adaptor is usually supplied so that a standard plug can be used. If one wasn't supplied contact the seller.
As has been pointed out reception on indoor aerials (especially in a kitchen) can be hit and miss (usually miss) at the best of times.
You could do worse than read this: http://www.avforums.com/forums/freeview/826100-freeview-f-q-s.html
BuyCleverStuff
Sounds like you have purchased one of the 10” Kitchen TV's we sell on our website;
Under Cabinet Flip Down Kitchen TV's
The two connectors on the rear are both standard 75 ohm coax antenna connects, just like you'd have on any TV…. but the Kitchen TVs has two independent tuners (hence why it has two connectors on the rear).
As for signal strength, portable aerials are not recommended (in my opinion) for ANY Freeview TV, we've tried many of these aerials and never had anything we could call a proper signal. Some of the better quality portable aerials can be very expensive £80+ and to have a proper “roof top” aerial fitted should really only cost around £150.
