Flickr upload problems
Discussion in 'Photography Forums' started by AVTEZ59, Jan 10, 2012.
  1. AVTEZ59
    AVTEZ59
    Jul 17, 2007
    1,251
    116
    +640
    Anyone experiencing failures today when trying to upload pics to Flickr ??....I am trying to upload one image only, and it fails every time- sometimes it sits at 54% for ages, some times it gives me a 'Bonk' message, other times it just does not respond.I've tried with a different image and the same thing happens.:rolleyes:
    Anyone ??
    Terry
  2. BubbleDouble
    BubbleDouble
    Jan 13, 2009
    4,227
    2
    Space
    +1,883
    I can't even sign-in to Flickr at the moment, so guess they've got problems.
    Although the server status is all green http://www.flickr.com/help/test
    Darren
  3. pips
    pips
    Oct 20, 2009
    506
    Worthing
    +52
    Just tried mine and all is working as it should for me :smashin:
  4. BubbleDouble
    BubbleDouble
    Jan 13, 2009
    4,227
    2
    Space
    +1,883
    Yep, seems better now :smashin:
  5. AVTEZ59
    AVTEZ59
    Jul 17, 2007
    1,251
    116
    +640
    Thanks all...back to normal !!...Established it wasn't a Flicker issue but my PC....decided to do a restore point to 31st Dec 2011.....worked a treat !!:smashin:
    Terry
