Flickering picture on any PAL material!
Discussion in 'LCD & LED LCD TVs Forum' started by Damian1978, Sep 24, 2005.
Tags:
  1. Damian1978
    Damian1978
    Jul 15, 2000
    4,512
    107
    Fleetwood, Lancashire
    +260
    Hi all,
    I have a 32" Relisys RLT3200 TV. Was really chuffed with it then a while ago the panel started to flicker through various sources but only when viewing 50hz PAL material.
    Its noticable on lighter menu screens etc and is like 50hz flicker you'd get from a CRT but a lot more pronouced. If you switch to a NTSC source like a DVD or Xbox its absolutely perfect and spot on. As soon as you switch back it starts again.
    Any ideas what it could be? Relisys don't know and want to take it away.
    Anyone know if these sets can be reset or have access to the service menus?
  2. Damian1978
    Damian1978
    Jul 15, 2000
    4,512
    107
    +260
    Anyone???
  3. Damian1978
    Damian1978
    Jul 15, 2000
    4,512
    107
    +260
    Well I've solved this problem.
    The panel is made by Harsper and there's a firmware upgrade that resolves this issue which affected a few panels.
    Its cured a few other bugs too and I'm overjoyed by this set again.
    If anyone has this problem give me a PM.
    Oh and cheers to Harsper Customer Services!! :smashin:
