Flickering patches on Xbox...
Discussion in 'Xbox Forums' started by PardonTheWait, Apr 20, 2003.
  1. PardonTheWait
    PardonTheWait
    I run my Xbox into my TV through a switching unit, using composite connections. Recently (last few days) I've been getting a flickering in the bottom right hand corner of the screen. It's only on the xbox, all my other consoles are fine, it's not the switching unit, because I took that out of the equation by doing the xbox straight to the TV, and it's not the TV because of the other consoles working.
    That leaves the cable and the xbox.
    Has anyone had this problem? I'm hoping it's common, so someone can say "yeah, tons of people get that, you need a new cable." . What I'm not hoping to hear is "tons of people get that, you need to send your xbox to MS and it'll be back in seven weeks"...
    Does anyone know? I'm probably going to pick up a new cable in the next couple of days, but if anyone has heard of this problem, I'd appreciate it if they'd tell me what's up!
